farginicehole
Thread starter- Joined
- Apr 15, 2003
- 482
I have owned this motor for about 5 years now, and it's always been ridiculously hard to start when cold, especially if it's been sitting for a few weeks or more (even if in warm weather). Last weekend, I put the muffs on it and after a LOT of cranking, it finally started to fire but not start. More cranking (I'm gonna kill my poor starter!) and finally it fired up. Smoked like crazy, but I figured it was about flooded and all of the old gas and fogging oil was burning out. Anyways, I let it run for a while, and it seemed okay. It always fires right back up if you shut it off and turn it over a few minutes later. Anyways, just this weekend, I put fresh gas in it and was going to take it to the lake. Knowing this motor's habits, I figured I could save myself some frustration at the launch if I started it in my driveway again right before leaving for the lake. The thing wouldn't even fire. Crank, crank, crank, and crank again. I took the plugs out, and sure enough, it was now flooded. I turned it over several times to clear out the cylinders, and let the plugs dry before putting them back in. After a bunch more cranking and not even a fire, I took the plugs out again and yep, definitely getting fuel! By the way, this time, I didn't prime as much to avoid flooding. My wife had gotten home by now, so I dried off the plugs and held them up against the head, one at a time, to see if I was getting spark. Only had spark on three of the six cylinders! We went inside to eat lunch. Then we came back out so I could try the plugs that sparked well on the cylinders that didn't spark, and nothing. Tried the plugs that didn't spark on the cylinders that did, and got good spark (okay, plugs are fine, and were new last fall). After more of this, a cylinder that WAS sparking stopped. Then it did again. Very intermittent. Is it possible that something could have gotten moisture in it to be causing this problem? I suspect, due to the hard starting of this engine over the past few years, that I've been fighting this problem for some time now and it's just gotten worse now. I would like to replace whatever ignition components you experts believe to be "prime suspects", as I've about had it. Any suggestions? And yes, I will order a manual a.s.a.p. Thanks much for any help!
