Battery not charging
MDeVito
I have a 1995 evinrude 88 special. I do not think the motor is charging my battery while it is running. How can I test this? What would the problem be?
Bradster941
Re: Battery not charging
Do a search, (top of the page), for charging. There are hundreds if not thousands of post on this topic.
MDeVito
Not exactly the help I was looking for. If you were going to waste your time posting that you could have just helped me out. Thanks anyways.
aaero12
Very simple test, using a voltmeter dc voltage, place red lead of meter on POS battery terminal, black lead on NEG battery terminal. First check battery voltage with motor not running and note voltage. Start motor and check voltage again, it should read higher than first reading, approx 12.7 to 14 volts.
MDeVito
Thank you aaero. I have no voltage jump, does this mean that my stator is bad?
aaero12
I don't know what type of charging system you have, I will assume an alternator. The problem could be in the regulator/rectifier. Most auto part stores can test this for free or little charge. Of course you have to remove the alternator from the engine.
MDeVito
It has what is called a stator, from what I understand, I dont know anything about them.
Bradster941
MDeVito,<br /><br />The point was, do a search first before posting a question as there are alot of discussions on most topics, and on All the topics in your many post..<br /><br />By doing so, you won't be waisting the time of those here who try to help others by having to re type what has already been written many times!<br /><br />Same goes for starting a new thread for every question you have on the related topic.<br /><br />Sorry you have such an attitude, but if doing a Search at the top of the page first is to troublesome for you, might I suggest you buy a manual? :confused:
MDeVito
Well as a matter of fact bradster.....I did do a search and it yielded no results worthy of the help I needed. So thank you for your suggestions anyways. I do have a manual also. :D
Bradster941
Then why didn't you read the manual.<br />It has the test procedures for the rectifier, regulator, stator, etc.<br /><br />And after doing a search, the search engine stopped at 300 post that more than covered your question. Imagine that... :rolleyes:
