OBJ
- Joined
- Dec 27, 2002
- 10,161
Re: 1975 9.9 johnson spark leak
'Nuther question dgassy, when you installed the new plugs, did you torques to 12ft lb.? This makes sure the two rings on the plug seat. And did you wipe off the seat before installing?<br /><br />Don't know what's up with the ohm meter readings. Maybe one of the other guys will know.<br /><br />When you put the cover on, make sure the latch attached to the cover isn't getting hold of a plug wire.
