Size of the bolts for the 3 flywheel puller holes- 1990- 60hp Johnson
fvassiliou
Thanks for your previous help Chinewalker. Perhaps you would happen to know the size of these bolts. Could it be 1/4inch #20 3 inch long?<br /><br />Thanks again!
G DANE
Re: Size of the bolts for the 3 flywheel puller holes- 1990- 60hp Johnson
1/4" are only up to 35 HP. A 40-50-60 HP will need 5/16" - 20
R.Johnson
The proper bolt is a 2" long stripper bolt, the size is 5/16-24. "Stripper bolt" is a machinist term for a shouldered bolt of much higher guality than found in a general hardware store. This bolt has only about 1/2" length that is threaded so that it is pulled down to the unthreaded shoulder, it is also used with a 1/8" thick tempered washer. The flywheel you are trying to pull is torgued down to 105 lbs. Using a run of the mill hardware bolt can result in a broken, or stripped bolt. Most machine supply dealers handle these bolts. Buy the proper bolts, and store them with your puller, they can save a big headache.
