wordmaster
- Joined
- Sep 14, 2002
- 27
Hi Y'all,<br /><br />I have an 82 model Johnson V4 90 HP with an idling problem. Here is the background. Every time I have run it up til this weekend, it has performed flawlessly.<br /><br />When I first started this weekend I noticed the tach seemed to be off. In the interest of not taking chances, I kept it below 5000 or so, but it seemed to be slower than that and had plenty of throttle left. Norm is wound out at 5200. This became better the more I ran it and after a while was back to normal, wound out at 5200.<br /><br />Everything smooth, I ran it across the lake and stopped at a marina. While pulling in to the dock, the motor died while idling. After that, it would idle very slow and rough and more times than not, die while idling.<br /><br />I can hear a miss at low speeds up to about 2500-3000 rpm, then it smooths out. at 4000 and above, it is as strong and smooth as ever.<br /><br />I changed plugs, (the quick and easy thing) and visually checked for obvious problems, the plugs made no difference.<br /><br />I cranked it and pulled each plug wire. the top one on the side away from the starter made no difference whether the wire was on or off. I pulled that plug, put it in the wire, cranked the motor, grounded the plug and it is firing very nicely. Looked inside the cylinder with a light, no obvious problems showing there. Is it safe to assume that the top and bottom coils hook to the top and bottom plugs respectively?<br /><br />Would the tach being wrong shed any light on the problem? What would be the most likely things that I could check?<br /><br />Any help would be greatly appreciated. Thank you in advance.<br /><br />OK, I pulled the wire from the plug in the "bad" cylinder and stuck a screwdriver in it. I cranked the motor and got a nice blue-white spark that went well over 1/2 inch, guestimate close to 3/4 inch between the screwdriver and the block. Spark was also jumping from the plug wire boot out to the insulated pliers I held it with to insert the screwdriver. <br /><br />Running in the dark though, with all wires hooked up I did not see any sparks jumping to indicate a problem with leaky wires.<br /><br />I hope to have a compression guage tomorrow, but what else can I try? <br /><br />Perry
