wavebuster58
Thread starter- Joined
- Feb 19, 2004
- 19
The motor seems to lose power after running WOT for about 15 minutes straight. I have been reading the forums about compression checks and decarbs. Today I did a compression check and the results were 120 psi on #1 and 145 psi on #2. I know that these should be closer together but it sure seems like good compression for the age. I put a little oil in #1 and it came up to 145 psi but after about 3 more checks it was back to 120 psi. I read today that nothing should be done until trying to decarb. I'm not against trying this but would someone please explain to me how this could help? The only thing that makes sense to me would be that the decarb would lower the compression in #2. Is this what I'm trying to do? What should the compression be? Thanks for any sense you can make of this.
