I have an 86---25hp evinrude that looses its spark to both plugs after it runs about 15 to 20 min. I have replaced the power pack---No help. I have checked continuity to the sensing coil(50 ohms) and the charging coil (600ohms)and checked both for shorts to ground. The kill switch is ok and the ignition switch grounds when off and is open when when on. I removed the coils and can not see any cracks or burn marks. I have wiggled wires until I'm blue in the face looking for shorts or open wires that are intermittant-no luck. I guess my next step is to replace the coils unless someone can give me a better sugestion. By the way the engine can set a couple of hours and then will spark again.<br /><br />Model E25TECDC<br /><br />Ser. No E0623542<br /><br />Thanks in advance for any help. I need to go fishing bad.<br /><br />N2Crappie
