I'm weak on my motor knowledge and only know enough to do very basic stuff. I decarbed with seafoam since it sounded easy enough and after following directins and letting it set for an hour I went started engine on muffs and the best way I can describe it is it ran irregularly. How do you type a sound???? Kind of a VRRRRMMM pause VRRRRMMM pause. Another split second and it would have died but it catches with power. Speeding engine up merely put more power and louder VRRRMMM and longer pauses. <br />OK so I had heard that if you have a bad plug wire that may be arcing you can spray an electronic cleaner onto it and will seal itself up. Sprayed on wires and it caught and ran great for about 10 seconds, so just kept spraying individual wires hoping to isolate which wire. No luck. But I did spray a cluster of wires at the top rear of engine that got it to run smooth for about 2 minutes. Then back to VRRRRMMM. I finally shut engine off after about 10 minutes of messing with it this way.<br /><br />HELP! I had this sound once before and took it mechanic and it wouldn't do it for him and when I dot home it wouldn't do it for me either. I doun't think I want to rely on my cure being hauling boat to mechanic and then hauling it home. Its cheap but unreliable.
