Re: Rivets vs. Welds
You'll notice all those expressing satisfaction with riveted boats are in fresh-water, fly-over country. I don't see a lot of airplanes nor riveted boats living in salt or brackish water. Nor are they any.....thats any...riveted white water boats (neither drift boats or jet boats).<br /><br />The reasons are various: 1) most riveted aluminum boats are not built of salt-water resistant alloy; 2) even tho aluminum, the rivets are usually a different alloy, thus allowing galvanic action; 3) riveted boats are significantly thinner than welded boats (that I've seen). As long as you keep them in fresh water, a good riveted boat will last you years and years. But put them in salt water, and even if you hose them down every day, they'll last no more that 5-10 years.<br /><br />My brother has the ubiquitous Smokercraft Alaskan...see them all over the Columbia River. But as soon as he started using it in Tillemook Bay, within 4 years, almost every rivet began seeping. Alaska charters use riveted boats usually no more than 3 years.<br /><br />To state that "welded hulls are never as true as a fiberglass hull" is ridiculous. There are at least 50 manufacturers of welded aluminum boats in the PacNW who would take money on that bet. They have experienced work forces, time-tested jigs, thousands of satisfied customers. And you pay for this quality...a typical PacNW welded AL boat is more costly than a similar fiberglass boat.<br /><br />But maybe there's really no discussion: comparing a Duckworth, Coastal Craft or Silver Streak to a Lund or Starcraft is like comparing a Filson coat to a Wal-mart jacket: both will keep you warm (at least for a while), but the Filson will be something you can hand down to your kids....<br /><br />OK, maybe I could learn to do better comparisons....
