dajohnson53
Thread starter- Joined
- Apr 28, 2004
- 1,627
I would appreciate any insight or words of wisdom.<br /><br />This is an older V6 carb'd engine (1982) but "remanufactured" in the mid 90s. <br /><br />I have an in-line bowl type water separating filter which I empty regularly as well as a normal little white in-line filter inside the cowling near the fuel pump.<br /><br />I put the engine up each fall with topped off tanks with fuel stabilizer in the tanks and run through the system.<br /><br />It can be very difficult to start when cold. It starts easily when warm. It idles very smoothly at around 7-800 rpm when warm (1200 or so when cold) and runs smoothly through the rpms to WOT at approximately 5500. I am very happy with the performance once started.<br /><br />My cold starting procedure. after checking fuel and air vent is to:<br /><br />1 pump bulb until firm.<br />2 lift the cold start lever fully<br />3 turn key to on (not start)<br />4 press key to prime carbs - hold for approximately 5 seconds (I can hear the switch inside the cowling when I press the key)<br />6 attempt to start engine.<br /><br />What happens is that the engine fires once (only once) and disengages the starter - at which point, I of course immediately release the key. <br /><br />It will do this time, after time, after time for several minutes. Seriously - this will happen many, many times for more than 5 minutes. One fire, starter disengaged. I have a strong battery and haven't had any problems (yet) with the battery running down before I eventually get it started. <br /><br />I vaguely recall occasionally having this problem iintermittently in past seasons, but never to the extent of considering it an issue. <br /><br />Eventually it always starts, but it does this one fire and out deal for a frustratingly long time.<br /><br />Once I get it started, I can shut down right away, before it's really very warm, and it will start right up again. If it cools down again, I have to go through the same routine. It always starts easily when warm.<br /><br />I have tried priming more and less - with no discernable effect. I have tried cold start lever up and down as well.<br /><br />This engine has an aftermarket jet lower unit. This means that there's no true "neutral". It's always pumping water and thus has a load, even at idle.<br /><br />It *seems* - but is hard to verify - that if I raise the engine to just where it pumps water, thus reducing the load a little bit, that seems to help. This is a vauge feeling on my part because it definitely doesn't make a night and day difference.<br /><br />The plugs look good to me but I'm no expert. But I haven't actually changed them (which is what I'm going to try next).<br /><br />I also haven't tried starting it on the hose to see if that makes a difference vs. starting it in the water. There is much less load while on the hose because the jet pump is not really pushing any water at all. I'm going to try this as well.
