1891 Evinrude 115hp lower end removal
mike69infl
I am trying to remove the lower end off my 1981 Evinrude 115hp engine. I have removed the 4 bolts on the sides of the lower end and the large bolt bt the prop. What othe bolts need to be removed and what do I do if it is stuck?
Dave Abrahamson
Re: 1891 Evinrude 115hp lower end removal
I'm no expert, but I believe that there is another bolt under the trim tab(above the prop). <br />And then you have to remove the shift shaft linkage bolt. Maybe someone else with more experience will be able to help you more. <br />Good luck<br /><br />Dave
rjarreau
you have to remove the trim tab above the prop and remove the 7\16 head bolt , also you need to remove the shift linkage screw from under the carbs you will see the stainless steel screw 3/8 head screw going thru the stainless steel shift linkage, good luck!!!
