what are pionts
rickdb1boat
Re: what are pionts
Do you have any serial numbers you can post or at least a description may help?
rickdb1boat
Re: what are pionts
I can't match that up. Maybe someone else can... It is a 40 HP Evinrude? Correct?
russeller
Re: what are pionts
YES EVINRUDE LARK 8 THAT IS ALL I HAVE GUY TOLD ME IT WAS A 67 BUT I DONT THINK HE KNEW
russeller
Re: what are pionts
IT IS THE ONE ON THE LEFT IS SAYS ON THE BACK COVER LARK VIII
russeller
Re: what are pionts
SORRY THE ONE ON THE RIGHT IS THE ONE THAT LOOKS LIKE MINE IF I HAD SOME NEW PAINT LOL
rickdb1boat
Re: what are pionts
Where did that model and serial number come from? Transom bracket??
russeller
Re: what are pionts
YES THE PART THAT IS ON THE BOAT WITH THE BIG SCREWS HOLDIN IT ON
russeller
Re: what are pionts
COULD THE PIONTS CAUSE A BACK FIRE OR BUCKING AT A SMALL IDLE ?
russeller
Re: what are pionts
I HAVE TO LEARN ON HOW TO FIX THIS I HAVE BEEN WORKING ON CARS AND TRUCKS FOR 10 YRS I CAN DO SOMETHINGS ON IT BUT I AM AFRIEAD I WILL BREAK SOMETHING
rickdb1boat
Re: what are pionts
Remove the flywheel as described above, replace or at least check the points and see what you come up with. Gap at .020.. MAny times Autozone will let you borrow a puller. Do not get one that pulls on the outside edges of the flywheel or you will have trouble. Harmonic Balancer Puller!!
rickdb1boat
Re: what are pionts
I have to ask one more time. Are those the numbers off the boat itself or the motor mount? Normally there is a small plate or sticker on the motor transom bracket(The part of the motor that sits on the boat).
russeller
Re: what are pionts
SORRY I AM AT WORK AND I JUST CALLED MY BROTHER AND HE GAVE ME THE WRONG NUMBERS HE IS GOING TO CALL BACK WITH THE RIGHT ONESOF THE MOUNT
rickdb1boat
Re: what are pionts
That's good! Want make sure you get the correct part for the correct year..
russeller
Re: what are pionts
HOW DID YOU LEARN ABOUT BOAT MOTORS ? TOO BAD YOU ARE FAR AWAY
russeller
Re: what are pionts
OFF HAD WHAT WOULD THE GAP FOR THE PLUGS AND THE PIONTS BE ?
rickdb1boat
Re: what are pionts
Learned alot right here on this forum and some more on my own over the years. There are guys here that know 10 times more than I will ever know! Your settings are J4C(J6C will work also, just a little hotter burning plug) Champion Spark Plug, gap at .030. I would open it up to .035 for trolling and better low speed running. Just works better! Points will be set at .020 when the points are at their widest point on the cam lobe. Turn the flywheel by hand to accomplish this.<br /><br />BTW- The best way to know your motor is to work on it yourself. A Manual is a must. This thread would not exist if you had one.. ;)
