procraftmark
Thread starter- Joined
- Sep 17, 2002
- 188
I pulled the head on my 90hp 1985 rudet to find<br />the is little scuff marks and little nicks in a good part of the starboard side lower piston these marks or nicks are in direct proportion to the roughed up area on the top of the piston! The mechanic told me a pice of ring must of broke off but there is no scoring of the cylinder at least in the area above the piston that you can see when the piston is moved from top to bottom by moving the flywheel .It almost looks like the piston was hitting the top of the head, but how is that possible? but like i said the the rough spots on the piston and head line up! Also I just did a compression check last yr and i had between130 and 115 all the way around now after this they do a test again and they are all around 100 with the affected cylinder being 75! my question is how in the hell did the other 3 unaffected cylinders drop? the hole thing is screwy does anybody have any ideas on this/<br /><br /><br />thnx<br />mark
