Re: Evinrude Fleetwin 7.5
There will be a fair amount of smoke for that motor if you're running the proper 24:1 mixture, and particularly if you're running it in a barrel. Rough running and such is also common when running in an unventilated barrel as the motor will suck in its own exhaust. Run it outdoors, with a fan blowing fresh air at the face of the motor. Better yet, run it on a boat...<br /><br />Make sure you install a new waterpump impeller - available over the counter any many places, including here at I-boats (part #18-3001). You'll have to remove the powerhead to release the shifter rod from the shift handle - not as big a deal as it may sound, but make sure you replace all of the washers and spring at the top of the driveshaf tin the correct order and grease the splines with waterproof grease.<br /><br />- Scott
