when i went and pulled my boat out for the year and get it running i at first tried to start it after putting in the lower unit lube after i had the motor running good and everything was fine i thought the water pump may have been bad so i pulled off the lower unit and to my surprise the impeller was good so when i put it all back together and tested it the prop automatically started to spin and after about 30 seconds or so the motor cut out and i tried to restart it and nothing so i checked the fuse and sure enough it was blown so i put in a new fuse and it blew after about 30 seconds of cranking so i did it again same thing and once more, same thing so i gave up,when the starter turns over it sounds weak and then it'll pick up, slow down, pickup, and so on until it starts, i have never had this problem before until i took off the lower unit to check the water pump ever since then i have been blowing fuses so do you guys think i need a new starter, the starter has never been replaced ever and i have a '72 100 horse johnson and after awhile the starter gets really hot if you guys know where to get a rebuild kit or a rebuilt used starter for a decent price let me know if thats the problem<br /><br /> thanx for the help and please respond soon
