carb off can i clean carbon out of block
jlehan
do u know of any sprays i can spray in the chamber to remove any built up carbon since i have the carb off? would like to get rid of any build up without having to remove the head :confused:
Mod2
Re: carb off can i clean carbon out of block
jtl....rebuild the carbs and put them back on then do the decarb. You need to get the engine up to temp before spraying in the decarb. You can use Bomby engine tuner or Seafoam products. Merc has one also. Follow the directions on the can.
jlehan
thanks will try when carb isdone
