Looking for Evinrude motor information
Vince1
I'm looking for some information on an Evinrude Lightwin motor. All I have is a serial number. Can anybody give me the HP and year of the motor, and any othere relevant info, from just the serial number? The serial number is 3012-06311. I believe it is 3hp but not sure.
Paul Moir
Re: Looking for Evinrude motor information
3012 is the model number<br />Evinrude 3012<br />Year: 1952-1954<br />HP: 3<br />WOT RPM: 4000<br />Displacement: 5.27 cu.in. = 86.5 ccm<br />Cylinders: 2<br />Weight: 32 lbs. = 14.5 Kg<br />Gear Ratio: 12:20<br />Spark plug: Champion J6C gapped at .030" (was J6J).<br />Fuel/Oil mix: 24:1 87 octane gas to TCW-3 rated outboard oil (ignore the decal about SAE30)<br /><br /> 1952 Lightwin<br />1954 Lightwin<br />From the old OMC Site<br /><br />That's an insanely great little outboard that was made in one form or another up into the 80's. I'm currently fixing up a 1972 variant for myself. :) <br />Yours is the first model ever produced.<br /><br /> Nice 3hp tuneup article.<br />Good luck! :) <br />PS - there's a fuel filter up inside the tank. Remove the brass nut above the fuel petcock to find it. It's often overlooked and clogged.
Vince1
Wow! Thanks for all the great info. It's actually not my motor, it's my Grandfathers. He bought it for $100 a few years ago and has only used it a couple of times. It runs great, he started it for me last weekend when I was up at his house. He had it in a barrel of water. He's probably going to be selling it, that's why he wanted the info on it.
CaseyStengel
Wow! is right. That was a fast response. Ok. I've got an Evinrude 55 HP, model no. 557730, serial no. E0001529. I don't know the year. I would like any info possible, like number of strokes, cylinders, etc. I am new to boating but am fairly technically oriented.
rickdb1boat
CaseyStengel <br /><br /><br />I don't find all that info on the site, but it is a 2 Cylinder, 2-stroke, 1977 Model. Oil mix is 50:1. Spark Plugs are Champion QL77JC4 gapped at .030.
CaseyStengel
Thanks Rick.<br /><br />What site could I have gone to? Any recommendations about repair manuals? Would the engine be too old to bother?<br /><br />Thanks again.
Paul Moir
If the engine has good compression then it's worth bothering with. Test that first. If you're technically oriented, spend the extra dough on an OEM repair manual. You can get reprints from the following places:<br />TheOutboardWizard<br />Mastertech<br />Marine Engine<br />Ken Cook <br />Good compression would probably be over 90psi, but most importantly have no more than a 10% varience between cylinders. There are no published compression specs for these engines.
