Johnson 88 SPL rough idle
mikecairl
Have owned this engine for 6 years and has always run great. The other day I was running wide open and the engine just died. After I restarted it the idle was rough but ran fine at any other speed.<br />I sprayed carb cleaner in the carb, checked all fuel lines, checked spark plugs all looked fine but still put in new ones, new spark plug wires this spring, checked all coils and have had no luck. Any ideas??
russeller
Re: Johnson 88 SPL rough idle
when is the last time you did a carb rebiuld ?
mikecairl
Never. I knew the previos owners and there were very few hours on the engine before I bought it.
Walker
Do a compression test. I hate to hear that an engine died at full throttle.
mikecairl
I did they were all very close to 115 PSI each.
mikecairl
I really need to fix this can anyone help?
Puttdrainer
I am having similar problems with my 88HP Johnson approx 1990..... and Ive been looking at the repair manual. It says the Fule pump diaphragms are fragile and a defective one produces symptoms that appear to be an ignition system problem. A common malfunction results froma tiny pinhole or crack caused by an engine backfire. THis allows gas to enter the crankcase and wet-foul the spark plug at idle speeds and stalling at low speeds. The problem disappears at highers speeds. I am definitely NOT a mechanic, but this info comes right out of the manual. I hope it helps.
