First off the motor is an Evinrude 33hp MODEL # 33653 which I believe is a 1966. I have cleaned the carbs float adjusted strait flat when upside down, new plugs J4J(.030). The motor had been sitting for about 4 yrs when I pulled it out and after cleaning it up a bit including carb and plugs at which time I also check compression and was approx. 95-100 in both cylinder's. The motor will start with just a tap of the choke when starting cold and after warm will start just as fast without the choke and raps out nicely. The problem I am facing is once you place it into gear it dogs down and will only go maybe 5 mph. This is on a small 14' boat that had a 40hp evinrude that had been locked up and it would run this boat approx. 25-30mph when it ran. I run 50/1 fuel mixture as that is what I have always ran on older motors like this one. There are two things that come to mind and the first is fuel pump has been replaced with a electric one(I have now the parts to switch it back if this is the cause)and has a clear in-line fuel filter in which you can see is always full of fuel and wonder if it places to much pressure but it doesn't seem to flood or foul plugs so I don't think it is blowing past the needle valve on the float. The second is the high level fuel/air needle as it seems very touchy when adjusting it. What I can't get is it raps out real good and tight, quick response and everything until I put a load on it then then I mine as well have a trolling motor mounted on there. Any ideas or suggestions would be great. Thanks<br /><br />Also another thing I was wondering about was the cam ajustment how it should be set. The book I purchased which is an Outboard Marinr Corp. repair manual believe it or not doesn't really show how to ajust or really very clearly it should be as to marks.
