bssmith270
- Joined
- Jul 8, 2004
- 2
After just spending lots to have Seadrive unit for 1988 115HP OMC repaired and new tilt/trim motor installed I have a new problem. Tilt/trim seems to have been working fine over last couple trips andwhen I went to get the boat today, I started the trim up for trailering down the road (had been in down position for about 4 weeks) and it moved slow. I stopped for a second and it hasn't moved since either up or down. T/T motor running fine, fluid level is full. Repairman who did the work has not ideas. Any help? Also, where is the override screw so I can manually tilt up to trailer? Thanks for any help.
