I have a 1974 Johnson 115 hp. <br /><br />We hit a rock and cracked the lower unit. Didn't know it at the time, and eventually it seized up, and wouldn't come out of forward gear. While this happened we yanked on the throttle, and broke the mechanism in the control box that takes it in and out of gear(the plastic teeth that engage the second pivot point.<br />I found a mechanic to replace the lower unit, and I replaced the part in the control box that was broken. <br />Something is not right and I need some help trouble shooting - I think it's in the control box, but I'm not sure. Here are the two symptoms<br />1) When going from reverse to neutral it stays in gear. From forward to neutral, we get neutral. At the engine head, the neutral position seems to be the same from either direction.<br />2) Full throttle seems to have moved at the control box, both forward and reverse. The handle needs to move much farther to get the boats to top speeds.<br />Thanks for the help - Hope I expained it well enough.<br />Bob
