Re: How to test
Since you've got brand new plugs in it, tell us what they look like at their firing end.<br />If your dropping a cylinder, the most common reason is a cracked ignition coil. Unfortunetly, the only conclusive way to test for that is to remove them and visually examine them. However, sometimes you can tell by how far a gap you can jump with them. You should expect to see it jump about a 3/8" gap.<br />What happens is, as the rpms pick up the magneto's voltage picks up, and at the same time the spark plug's gap gets harder to fire across because it's firing closer to TDC. So the spark finds an alternative path through the coil's insulation to ground.<br />You can isolate the ignition system from it's various cutouts by disconnecting and isolating the two wires from the armature plate up underneath the flywheel. You'll have to choke the engine to stop it though.<br /><br />Good luck!
