Just hit rock and broke lower case. As best i can tell all the internal parts are OK . Have started dissasembly, have the lower case removed ,prop seal is removed, shift linkage is out, need instructions on removing prop shaft and drive shaft/pinion gear assembly.<br /><br />Thanks<br /> John
