right prop?
hydra-sport
I have a 19ft hyrdasport with a 200 GT Johnson, just had the stator replaced and my tach is now working. I am running 4500 rpm's at full throttle and only getting 44 mph. Running a 26 pitch shooter 13 1/4 4 blade prop, real slow getting the bow down. Please help......
Dhadley
Re: right prop?
Are you sure the tach's set on position 6?<br /><br />Do you have a jackplate? The Shooter bites pretty hard (as you see) and likes to run high.<br /><br />Youre almost 1500 rpm off your target rpms. Lets varify the tach first.
hydra-sport
Re: right prop?
Yes I have a jack plate and it is set in the middle. My rpm's are 4500 at full throttle at full trim. Not sure what my tach is set at.
Dhadley
Re: right prop?
Cool. Lets verify the tach setting first and then raise it a bit. <br /><br />Note the water pressure and keep an eye on it as we go up.
