I have a 1994 225 Ocean Runner on a 94 bristol Hydra Sports hull that was purchased in March of this year. The engine had a powerhead rebuild at Gator Marine in Florida in January before I purchased the boat. I broke the motor in properly and have run it several times offshore with no problems. On Saturday, 46 miles offshore, steady warning horn came on indicating an overheat situation. I shut motor down right away and removed engine cowling. I could place my hand on the port head for a couple seconds, starboard seemed a little hotter. Had good pee stream since I have owned it and appeared to be the same. Had to idle back into port at 5 knots to keep horn from coming on. That was as fast as we could travel. Got to friends house and removed thermostat on hotter starboard side and horn still came on. Seemed to also notice that water pressure seemed lower that on previous trips. Now around 10-12 psi. Should I start with a water pump kit and thermostats and see if that eliminates my problem first? BTW, on the powerhead rebuild ticket, I see no parts that would suggest a new water pump was put on motor at that time. Any other ideas? Also, any sites that I can find water pump replacement directions at? Many thanks...
