lower unit past pressure test, oil is still milky
ggreen
I run a evinrude 30 I believe the year is 1995. I have had the lower unit pressure tested twice at a marine. Both tests passed, however after a day of running the motor the oil comes out milky. I metioned this to the mechanic after the fist test. Problem not resolved. Any ideas what could be causing this? I bought the engine last summer so I don't know the past history.<br />Thanks
Dhadley
Re: lower unit past pressure test, oil is still milky
Welcome!!<br /><br />Passed the pressure test -- what about the vacuume test? He should have done it the first time and certianly the second time. Or did you just specify the pressure test?
Terry H
One other thing to look at are toe gaskets/orings on the fill and vent screws...chances are your mechanic is putting the old ones back in after the test...just a minor thought :)
ggreen
Originally posted by Chief 101:<br /> One other thing to look at are toe gaskets/orings on the fill and vent screws...chances are your mechanic is putting the old ones back in after the test...just a minor thought :)
ggreen
Thanks for your imput. I did change the orings on the two screws. At the marine I was told that evinrude switched orings on the fill and vent screws then changed back to the oringinal style?
Terry H
ggreen...take heed what Dhadley says...he knows his stuff... :)
ggreen
Originally posted by Dhadley:<br /> Welcome!!<br /><br />Passed the pressure test -- what about the vacuume test? He should have done it the first time and certianly the second time. Or did you just specify the pressure test?
ggreen
Thanks for reply. I checked my bill and they did a 2.5 hr pressure test and a 3.5 hr vacuum test and found no leaks.
ggreen
I checked my bill and a pressure test was done for 2.5 hrs and a vacuum test was done for 3.5 hrs. no leaks where detected.
