Can't get forward gear
malibu4u
I have a 1992 Johnson 15 HP outboard motor Model No J15RENM. Yesterday I replaced the throttle grip and the plastic shims inside the grips. I have everything lined up properly when I put it back together(I thought) but I cannot get forward gear. I have reverse but that's it. Any suggestions? Thanks.
russeller
Re: Can't get forward gear
does the motor go in to forward ? or just not going into the gear in the lower end
jimmbo
try rotating the prop as you shift into forward
malibu4u
tks jimmbo for your advice about rotating the prop. Just what the doctor ordered. Works just fine now. :D
