I'm lookin for a little help here. I replaced the powerhead on my 1985 120hp OMC SeaDrive which is comparable and uses the parts from Johnson and Evinrude. My powerhead did not have a "bubble" on the back but the remanned one does. Now there is this overheating problem that for weeks(4 or 5 now) cannot be solved by our mechanics since we had the powerhead changed. It will idle for a few minutes and then the alarm will go off (constant beep noise). This led us to replace the water pump and housing, impeller, and the thermostats and it still overheats. Supposedly the cooling passages are not clogged. Can anyone offer me any insight on what may be wrong because im going nuts here not being able to use my boat all summer now. Is there a diffrence between the motor I had and the "bubbleback". Someone said something to me about the gasket between the powerhead and the lower unit if it means anything.
