ballisticvoodoo
Thread starter- Joined
- Jul 24, 2004
- 2
I'm getting ready to go on a trip in a few weeks, and the last time I took the 14' Alumacraft out with my 5.5HP Johnson CD-11 1954 Outboard, I noticed that the top gasket on the Mile Master fuel tank (the gasket that the top handle and pressure pump and filler cap is in) was leaking.<br /><br />So, I proceeded to remove the screws and pull off the top tank handle/pump assembly.<br /><br />I carefully removed the cork gasket, in case I wanted to make a new one from it, (likely will use RTV) and noticed another gasket and thought I'd inspect it's condition.<br /><br />BIG MISTAKE. I undid the screws like an idiot, and out came two springs, a valve seat disc of some sort, and an aluminum washer, as well as a plastic & rubber plunger.<br /><br />Can anyone help me reassemble these things?<br /><br />If not, can anyone give me tips on a replacement fuel tank to use with this motor?<br /><br />Also, does anyone know of replacement tank pressure pump gasket/diaphragm parts? Mine's cracked and might not last another season.<br /><br />I'd be grateful!
