1960 Johnson seahorse question.
Porto
Hello, I have a 1960 Johnson Seahorse 18 hp that I use 24:1 gas oil mix in. I just picked up a 1961 Johnson Seahorse 18 hp. My question is, does this motor also burn 24:1 gas/oil mix?
Paul Moir
Re: 1960 Johnson seahorse question.
Yup. They did that up until 1963. In '64 they switched all their motors from 24:1 to 50:1.<br /><br />Old OMCs are addictive, huh?<br /><br />PS - Have a look at this page from the '61 catalog:<br />Page<br />I belive that the small end connecting rod bearing was the last one they changed from plain to anti-friction.
Porto
Thanks..... The guy I got the motor from told me he burned 50:1 in it for the 1 season he had it. He said he "just assumed". How much damage could this have done to the motor? It seems to run fine, I've watched the guy run it on the lake I live on.
Paul Moir
Probably none at all. There's not much difference (mabey no difference) between the '61 engine and the post-63 18hp engines that ran 50:1 spec. <br />But there's no good reason to run so little. If you want to reduce smoking, try a synthetic 2-stroke oil instead of reducing your mix.<br />Check out the Oil Mix FAQ in the FAQ forum for more information.
Porto
Great, thanks. I'm hoping to put both 18's side by side on my 1955 14 foot Tomahawk. Yes, old OMC's are addictive. If I bring home another boat (or motor), my wife is going to kill me.
RCRCRC3
yeah i have a 1961 75hp and a guy at the local marine said to run 50:1 because it has roller bearings in it but should we still be running 24:1 then?
Paul Moir
Yup. <br />You can judiciously mix it leaner, but it's survived 40+ years on a diet of 24:1 so why mess with it?
