can not get a spark from right bank <br />(in neutral or in gear)tried disconnecting shift switch same problem also tried disconnecting black with yellow tracer at switch with no results,should this wire have any voltage at all(has.03 volts).any other suggestions,does anyone know if the right bank starts working at a set rpm or once it"s put in gear it should be firing
