AIR IN FUEL FILTER
JCSO4204
I have a 50 hp evinrude and I have disabled the the oil injector, the boat ran good for a few days now it will not plain out. There is a air bubble in the fuel filter and the fuel ball is soft. What do I need to do? :confused:
D
DJ
Guest
Re: AIR IN FUEL FILTER
Where is the fuel filter?<br /><br />Did you close off the oil injection inlet?
JCSO4204
The filter is near the starter, I put a large bolt in the o.j line.
D
DJ
Guest
Is the fuel filter a new addition?<br /><br />You did mix the fuel 50:1?
JCSO4204
No the filter has been there, I did clean it. and yes I have mixed 50 to 1. I have dumped the old gas thinking that may be it.
JCSO4204
Also if I pump the fuel ball the filter fills up, and the when you throttle up the filter empties and a small flow of gas is all I get. At a full throttle just put along.
JCSO4204
D
DJ
Guest
You are pulling air in somewhere. Check the line carefully between the fuel pump and the bulb.
JCSO4204
ok I bought a new fuel line from the tank to the motor today, will check the other lines too. thanks
