DavidcFlorida
Thread starter- Joined
- Aug 1, 2004
- 7
hi first time to this site, i hope someone can help me. First boat iv'e owned, evinrude 150, model e150trlcsr is on the tag and e150trlcsa is on th engine, i bought the boat after it was sitting for 2 years, took the boat home changed the plugs and it was very hard to start. It felt like it was real tight. i've worked on many cars and it felt like timming was off cranked real slow and tight. finally got it running and took it out for the day. ran very well for the day started back tward home and it died on me. i looked thing over and found a dry rotted fuel line sucking air. cut and fixed it got it running again. started home it died again. had to get towed in, took boat apart and and completely rewired the entire boat and engine. no wire was left (not getting towed in again)lol. after redoing entire boat over put engine back on and tryed ti start it. 2 brand new batteried with a isolater switch, engine still turning over very tight. did compression check, got between 95 - 100 on all 6 cylnders. replaced starter with brand new one (not rebuilt) replaced 3 coils that seemed coroded and all wires. checked spark and good spark. everytime i crank it over it just seems too tight to crank, it does crank but starter heats up quick so i can't keep cranking it. batteries are at full charge (2 marine batteries)but it turns over like there is not enough juice, i have tried everything i can think of. PLEASE HELP>............ i have also cranked the engine over with all spark plugs out and it turns over great and cranks normal, but when i put them in it just seems to me that the engine is real tight, also i have pumped the bulb and tryed everything as fuel goes, ie...spray starting fluid in and it just seems to tight to get a good cranking speed to start. it has tried to start but won't. I currantly took carbs off and i'm rebuilding them, can fuel problems make the engine tight while cranking? what can i do to make it crank normal? THANKS IN ADVANCE IF YOU CAN HELP ME......david
