marinemech
Thread starter- Joined
- Aug 12, 2004
- 250
a compression gauge doesn't always give a true reading of the cylinders conditition a better way to tell if you have a cylinder down is to rotate the flywheel with a wrench and feel the compression you will be able to "feel" if you have a low cylinder i almost never use a gauge to check compression<br />also while rotating flywheel you should be able to here the reeds work
