Hello all,<br /><br />What an asset, I never new a forum like this existed!! <br /><br />My problem:<br /><br />My outboard seems to have a problem restarting after running. After some questionable work to get it started at the ramp(takes many false starts to get to idle nicely) and running to the fishing hole, the motor doesn't want to start back up easily. When I come off plane and move to idle speed the outboard wants to stall, only corrected by increasing the fast idle lever/choke?. If it does stall or I stop to fish, it takes requires a lot of cranks to get started again, normally requiring increasing the FIL/choke? again even after the motor is warm. Any suggestions would be greatly appreciated!<br /><br /><br />Some added info:<br /><br /><br />I had the stator replaced about 4 months ago, but have not used the boat much. The problem may have started after that. Could the timing be off???<br /><br /><br />When at Full throttle, the motor seems to miss occassionally. ~ 5500 RPMs. Normally don't run this fast but gotta avoid lightning here in FL. Thanks again<br /><br />Scott
