1969 115 evinrude no spark
capt quint
Hi and thanks for reading, <br /><br />I am tryign to figure out why my 1969 115 HP evinrude will not start, she cranks just fine, and i get no spark. when i purchased this boat a few weeks ago she started up just fine for me when the p/o demo'd the motor for me, now she wont start. i took a plug out and held it to the block, and i got no spark, i did this with all 4 and there is no spark. how can i further diagnose this problem?<br /><br />thanks for reading
rickdb1boat
Re: 1969 115 evinrude no spark
Is there a kill switch on the control? Check that out first if so...
capt quint
i dont see a kill switch, its a electric shift with a single lever and 3 buttons, fwd, neut , rev. would there be a hidden kill switch
ledgefinder
Ensign
If you're sure it's a 1969, is has a battery-powered ignition, with a trigger coil & pulsepack (powerpack). <br /><br />If the battery got disconnected backwards since you tested it, that would've killed the powerpack immediately. If the fuse & rectifier are blown, that's it. <br /><br />Otherwise, the diagnosis starts by checking whether 12V is getting to the powerpack. We've been through this often, so please search the archives here for a complete description. Post back if something's unclear.<br /><br />Good luck!
capt quint
Ok im getting power to the pack, and im goign to try swapping out the coil with one from a fiends motorcycle and see what goes on, there is no kill switch and all of the fuses are fine, where else should i look
captain spike
capt,i have the same motor had the same problem!!hook battery cables wrong fryo!!!!!!!!unfortunetly there pricey but i bet thats the problem.you should invest in a good good manuel has alll test and troubleshooting guides in there.also ,you probably fried the rectifier like ledgefinder said these motors are very finicky i love mine took sometime to figure it all out but with the help of the good people of iboats it really rips and runs mint!!!goodluck you should be able to find any parts online
bdubya06
Capt,
what did you find out here?
Im having the exact same issue with my 69 115 hp evinrude!
bigbadchevy89
What is the propper way to unhook a battery? I just purchased one of these engines and I am waiting on my manual to come and wondering is there somewhere I can view wiring diagrams at now?
D.C.
