1977 35hp compression
JHar
A quick question, I ran a compression test on my motor this afternoon and came up with some puzzling results. I got 95 psi on each cylinder. Is this too low? I'm behind on my maintenance for the year and was preparing to rebuild the carb, install a new water pump and change gearcase lube, etc. Should I consider a rebuild or a newer motor? Late last season the motor was on occasion cranky about starting. Thanks.
JB
Re: 1977 35hp compression
Your numbers are fine, JHar. Both cylinders the same is about as good as it gets.<br /><br />The only thing you might consider is a decarb.<br /><br />Good luck. :)
JHar
Thanks JB, I'll take you up on that. What is your recommendation for the decarb?
JB
I'm one of those dinosaurs who still decarb with water, JHar. I wont recommend it because it is risky if you don't do it exactly right and I would be shouted down by the more modern thinkers.<br /><br />Check out the excellent decarb advice in FAQ.<br /><br />Good luck. :)
