Wanted: Repair manual 1988 Johnson 110hp
z71crazyman
Hello ladies and gentlemen. I am looking for the above mentioned repair manual. I found a couple and one on a particular website for 25 dollars and was wanting to check and see if I could snag one from someone else first. A new one runs close to 45 dollars and I am just curious.<br /><br />Thanks for any help.
madbanchee
Re: Wanted: Repair manual 1988 Johnson 110hp
I would suggest you get the OEM manual since it will cover your motor specifically. The aftermarket manuals seem to be too general usually covering a wide range of motors. I looked for a manual the same as you and bought a Clymer's but then soon after ended up buying the OEM from Ken Cook anyway. Guess what, the Clymer's I have doesn't even look dirty or used.<br /><br />Go to your local library and look at one before you buy it. Sure, many of the libraries won't let you check out reference books but it gives you the chance to try before you buy. The library may in fact have a couple of books from diferent publishers.<br /><br />The (often times) lack of information from a third party (aftermarket) book and the headaches caused from it is not worth the ten dollars saved.
z71crazyman
Thanks for all your help Madbanchee and JB and i will be getting a manual (OEM) and what not.<br /><br />Have a great day.
