Matthewgordon
Thread starter- Joined
- Aug 29, 2004
- 3
I have a '77 johnson 70HP. I have had the motor running, but gas comes out of the bottom carb. It comes out when engine is off and I squeeze bulb and when engine is running. I took out the spark plug and nothing changed. There is no spark on the bottom plug. WHen I get it started, and it takes a while, it runs high RPM, revs, then goes down to idle, which is terrible, then stalls. It varies, sometimes it stalls immediately, sometimes it will run for a few minutes, but it always revs up then down, like too much fuel is building. I was going to take off the card to inspect but I can't get to the bottom one easily without really dismantling them motor. There is low compression in that cylinder, about 90 lbs aposed to the 120 lbs in the other two. Before I take it to the boat shop and leave it there forever and then get billed like I'm bill gates, is there anything I can do to narrow down what the problem might be. My guess would be the float stuck or obstruction of seat, but I am by know means a mechanic. It was winterized and then sat for 4-5 years. I can't spring for a rebuild now and would just like to get it in the water a few times before the end of the season. THanks for any help.
