johnson 78 115 v4 stalls when motor is not tilted
nektwister
Hi I have a quick ? when I start my johnson up if the motor is straight up it will stall out after about 45 seconds and is real hard to start after but if I give it some tilt maybe 25 degree tilt it runs perfectly while at idle and once it warms up it will run without the tilt. I kinda of think the carbs are loading up but that is a geuss is it in the right direction. Thanks 4 the help GIT R DUN
JB
Re: johnson 78 115 v4 stalls when motor is not tilted
I agree that it sounds like carbs, LDH.<br /><br />Careful attention to float needles and float levels.<br /><br />Good luck. :)
