Re: 1974 25hp Evinrude Pops out of forward gear
Hi Tim <br /><br />To get a better diagnose of the problem, try following: When you get near the speed when it starts to jump, place a person where he/she can reach the gear shift lever. Try to hold it in forward position, and increase speed. If it gets possible to get to higher speed before the jumping starts, and gear lever then if forced against neutral, worn clutch dog is the culprit. On your motor, which is a horizpntally split gearcase, changign clutch dog is an operation that can be done by a normally mechanical inclined person, guided by a repair manual for the motor. Clutch dog is around 80 $ as far as I rember, still available at Johnnyrude dealers. Running it this way will spread the harm to the lobes in forward gear too.
