Mark42
Thread starter- Joined
- Oct 8, 2003
- 9,334
OOPS! I wasn't paying attention and got in shallow water and hit a rock at about half throttle. The prop is an aluminum Turning Point Hustler model. There are two flat spots on the leading edge of two blades near the tip about 1" long each. Does not look like much damage, but it is enough that I noticed a mild vibration and when went WOT, the vibration is worse and the top end is cut about 1-2 MPH. The blades do not look bent, its just the leading edge that took a wack.<br /><br />So I need to know the way to go about balancing the prop. I can easily file the impacted (sort of flattened) edges back to a sharp edge, but what about balance? Where do I remove weight from on the blade that was not impacted? <br /><br />I did some searches on this topic but did not find anything on balancing a prop. <br /><br />Thanks,<br />Mark
