ignition swap 1989 to 1985 ..140
tony120
im looking to swap my ignition on my 1985-140 for the ignition on my 1989-140,cause it has the quick-start.is it a straight swap as long as i use the flywheel,stator and the powerpacks from my 89-140? thanks
Hooty
Re: ignition swap 1989 to 1985 ..140
It looks to me like it should be a straight swap out. If you do have any problems, post 'em.<br /><br />c/6<br />Hooty
Dhadley
An excellent idea. Just be sure to use all of the 89 components including the flywheel. Be sure to keep the flywheel with its own ignition. Double check timing when done.
