correspondant2003
Thread starter- Joined
- May 19, 2003
- 4
Hello,<br /><br />I'm having a problem with my Evinrude twin-barrel, 40hp outboard. Basically, any new spark plugs that I put in provide good power for about only 1 hour of operation. After that, I have trouble planning the boat. Any suggestions why?<br /><br />Here are some hints:<br /><br />- A new set of plugs will give me good power for only 1 hour<br />- After the 1 hour, if I remove the plugs, the top one seems to be clean but wet with fuel<br />- The bottom plug is dark grey but dry.<br />- I tried with 2 new sets. When both gave me the same result after one hour, I tried mixing the 2 sets: if I put the 2 clean/but wet plugs together, I can't even start the engine. If I put the 2 dark-grey/dry plugs together, the engine runs (but eventually loses power).<br />- The fuel/oil mixture that I use is good: 50 to 1.<br />- It's new fuel.<br /><br />'Appreciate in input.
