Re: Rebuilt 150hp runs, but overheats
Well, we checked the impeller, and it's OK, while we had the gearcase off, we connected a garden hose to the water intake and ran it. Water does run through the block, and out the lower pee spout, as it did when we ran it. <br /><br />Withthe hose attached, the water comes out the lower unit (with the gearcase removed) and it also comes out from behind the shroud around the bottom of the engine compartment. Is that normal???<br /> I'v looked at the gasket that goes between the power head and the exhaust port, but that gasket isn't leaking (which is where the water comes up.)<br /><br />I've gone over the rebuild in my head and I know <br />that all the gaskets are installed correctly. <br /><br />What else can I try? Where does the water flow from the copper pipe up to the thru power head?<br /><br />Where is the thermostat?<br /><br />Mik
