I just finshed putting the center console in my 1960 Starcraft 1978 55hp Johnson no regulator that I can find. Plus all the gauges it didn't have. Water Presure, Tach, Head Temp, and Volt meter. All controlled by a seperate switch from the battery. Stayed out of the control box, because manual said "Do Not Connect Anything to the ignition Switch."<br />The volt meter only shows 12 volts at 1000 rpm with the ears on (haven't put it in the water yet) shoudn't it be 13-13.5 volts? I also have a good tatle tale stream but the water pres. gauge only shows about 3lbs is this right?<br /><br />You guys are the best!<br />Thanks Smitty
