Hi. Newbie here. Glad I found such an informative place to discuss boating and related issues. I searched on this topic and din't see much there to help - so here goes:<br /><br />I have a mid 90's era Evinrude 9.9hp - 2 cycle. It runs for a few moments and then dies due to lack of gas. I just replaced the fuel line and the tank is also new. The tank doesn't seem to be the issue as I opened the cap to ensure there is no vacuum within the tank. The only way to keep it running is to disconnect the fuel line from the tank (you here a hiss as the vacuum is released) and then re-connect. What could cause the vacuum in the fuel line (which seems to be the issue) when its not being caused by the tank (again - happened when tank cap was open)? Is this classic fuel pump issue and, if so, is there any other way I can test to ensure that is the cause? I plan to take a friend and his son out after this is fixed and I hate to have another 1 hour+ trip back to shore as I had last Sat.<br /><br />TIA,<br /><br />CSquid (AndrewT)
