25whaler
Thread starter- Joined
- Nov 24, 2003
- 33
150 warning horn/buzzer
good morning all. I am looking to add a warning indicator light to my 1986 johnson 150. The horn is operational and located under the dash and is difficult to hear at wot. Not able to move to a good location either. I wanted to add a warning indicator lamp on the dash. This would lite when there is a problem. Looked into adding system check but it is not cost effective as I have twins and would not be worth the cost. I was wondering if anyone knows if this can be done. I believe the tan wire shorts to ground when temp gets too hot etc. This would makethe horn go. would I be able to run 12v to a indicator lamp (mounted on the dash) and the have the ground for this light tied into the tan lead going into the horn. I would like to use both the horn and the light if possible. My thought is the light world work the same time the horn is going. (either steady for temp/fuel or blink in series with low oil etc) Any assistance would be grateful. Thanks to all and have a great day!!!!
