evinrude rebuild
big jilm
im looking at this old checkmate with an old evinrude 200 on it. the motor has low compression throughout (95 psi). would it be worht it to rebuild this motor? i can get the whole setup for $800. the motor does run, the boat just wont get above 40 mph. i could do the rebuild myself with the help of a friend so....... is there a set kit to rebuild one of these?<br />
NOSLEEP
Re: evinrude rebuild
Whats wrong with 95 psi. Is that what it is on<br />all cylinders? Maybe it might just need a decarb.
Dhadley
If you like the boat, go for it. I think your lack of speed is elsewhere than rebuilding the powerhead. If compression is that even its probably OK.<br /><br />Is that the 20' Checkmate?
big jilm
i was told the comp. should be around 115 psi. yeah its a 19 ft ski mate. i dont know much about it. ill have to go back for another look when its not raining.
Dhadley
The compression numbers depend on what heads it has and even which head gaskets. Gauges vary, proceedures vary, cranking rpm, starter condition and on and on. If its that even you probably have a good base to work from.
fireman57
I'm with them. Decarb. As long as all the cylinders have the same compression it sounds like nothing has been hurt. What is wrong with 40? If it has been sitting for a while I would change the impeller in the water pump and clean the carbs. Sounds like a sweet deal.
big jilm
what is this decarb you speek of. also, 40 doesnt sound right. a 200 o/b with a 19' boat should do 65+. i already have a 16' mate that does 55. i have a merc on it. i was just wondering if it would be a pain to go through this evinrude.
AMD Rules
Tell me where it is located...I'll go take a peek for you. Honest... I won't take 800 cash with me.....well......schweet boat !!
R.Johnson
The flim flam we are operating here is , with your experience, and you are way above us, is ! Why don't you figure it out? Another question! could you put a handle on an outhouse door, and get it straight?
big jilm
Originally posted by R.Johnson:<br /> The flim flam we are operating here is , with your experience, and you are way above us, is ! Why don't you figure it out? Another question! could you put a handle on an outhouse door, and get it straight?
geez what are you upset about. the fact that your a jerk? whoops. im asking a simple question.
Solittle
I would think you could get $800.00 out of the motor alone if you sold it.<br /><br />It would not really be a pain to go through the motor just time, money and work. If it were mine though I'd see how it runs before turning my wallet upside down and shaking vigerously. The other post are right on.
big jilm
oh yeah i plan to run it before i purchase it. i got burned once on my first boat purchase. i learn fast.
