rogerwa
- Joined
- Nov 29, 2000
- 2,339
Re: Used Honda Civic on water?
A deckboat would be your best bet.. You need the utility of a pontoon (for people capacity) and the v-hull for cruising and skiing etc..<br /><br />A lot depends on your budget. The deckboats, at least newer good looking ones, come at a high price. If $22K is in your ballpark then you should be able to find one.<br /><br />The Chapparal is the best of the breed, I believe, in the brands you mentioned. Although any hull well cared for will serve you well. The powerplants are all the same with the exception of the decision of Mercruiser or Volvo. I own a Merc myself, but have heard that Volvo is superior. I guess it depends on what your mechanic will service..<br /><br />If going with the Deckboat, I would recommend at least a 5.0l V8. Bigger if you can afford it. With all those girls, you'll need the ponies to get up on plane..
